Interactive MCP Apps: When to Build an MCP App Instead of an Agent
An interactive MCP App exposes enterprise MCP tools through deterministic forms and dashboards — giving users governed access to business systems without requiring LLM interpretation of every input.
What Is an Interactive MCP App?
An interactive MCP App is a structured, UI-driven application that exposes enterprise MCP tools through deterministic forms and dashboards — giving users predictable, governed access to business systems without requiring the LLM to interpret free-form inputs.
Where a conversational agent accepts natural language and figures out what to do, an MCP App presents structured options and collects inputs through forms. The LLM may still be involved in processing, but the interaction surface is controlled and predictable.
When to Choose an MCP App Over an Agent
The choice between an MCP App and a conversational agent comes down to how much structure the use case permits and how much risk ambiguity creates.
Build an MCP App when:
- The action is high-stakes and must be executed exactly right (financial transactions, record deletions, compliance-sensitive operations)
- The inputs are known in advance and can be validated before submission
- Users need to verify what they're submitting before it executes
- The interaction pattern is repetitive and the same users do it frequently
Build a conversational agent when:
- The user's need varies significantly across instances
- The right action isn't clear from context alone and the agent needs to ask clarifying questions
- Discovery is part of the value (the agent surfaces things the user didn't know to ask for)
The Three MCP App Patterns
Workato supports three MCP App implementation patterns:
- Form-Driven Execution — the user selects an action and fills in parameters
- Guided Data Collection — the app walks the user through a multi-step data gathering process
- Dashboards — the user views and interacts with analytical data surfaced through MCP tools
Governance Benefits of MCP Apps
MCP Apps enforce determinism at the interaction layer — the user can only do what the form allows. This is a governance feature, not a limitation. Every submission is a structured, logged, auditable event. Contrast this with a conversational agent where the same outcome might be reached through many different paths, some of which are harder to audit.
