Chain of Thought Prompting for Enterprise Agents
Chain of Thought prompting instructs the agent to show its reasoning step-by-step before producing an answer — improving accuracy on complex reasoning tasks and making agent behavior auditable.
Design Patterns Prompt Engineering
What Is Chain of Thought?
Chain of Thought (CoT) prompting instructs the agent to reason through a problem step-by-step before producing its answer or taking action. By externalizing the reasoning process, CoT improves accuracy on complex tasks and makes agent decision-making auditable.
When to Use It
  • Complex analytical tasks where intermediate reasoning matters
  • Classification or routing decisions that require considering multiple criteria
  • Any context where you need to understand why the agent made a decision
  • Tasks where accuracy is more important than speed
When NOT to Use It
  • Simple lookup tasks where the answer is straightforward
  • High-volume, latency-sensitive tasks where reasoning overhead is costly
  • Tasks where the agent's reasoning is irrelevant to the user
How It Works
The prompt instructs the agent to "think step by step" or provides a structure: "First, identify the relevant factors. Second, evaluate each factor. Third, reach a conclusion." The agent's reasoning becomes part of the output, not just the answer. In Workato, CoT is implemented through Genie prompt design — the job description instructs the agent to reason explicitly before acting.
Put these cookbook patterns to work
Get started
