Controlled Data Volume Pattern
The genie applies filters, aggregation, and pagination before returning data to the LLM, to prevent context-window overflow when working with large datasets.
Why This Pattern
This isn't really a stand-alone pattern so much as a discipline every other pattern needs the moment its data volume is unbounded. Token budgets are a hard constraint, and an LLM asked to aggregate a large raw dump fails silently — a subtly wrong summary — rather than obviously, which is more dangerous than an outright error. The judgment call: push aggregation and filtering down into deterministic code, and keep the LLM's job to reasoning over an already-small result, never to being the aggregator itself.
When to Use It
- The underlying dataset is large enough that returning it in full risks consuming the entire context window.
- The user needs a summary or filtered view, not every raw record.
When NOT to Use It
- Never return bulk data straight from a skill. It can consume the entire context and cause lost conversation history, errors, or incorrect data.
- Don't rely on a knowledge base for definitive answers like sums or counts across many documents — vector stores return the top-N matching fragments, not the full set.
How It Works in Workato
- Perform aggregation, filtering, and data processing before sending results back as skill output — not after.
- Implement pagination to return a limited number of records at a time, sending only the relevant fields, plus a message indicating there may be more results.
Source: Agentic Design Cookbook V2.0, pp. 23–24
