Genie as MCP Server
A genie exposed as an MCP server can be called from Claude, ChatGPT, custom UIs, or other agents.
Why This Pattern
The build reasoning is about where the genie's front door should be. If the natural entry point is a custom UI or another agent — not the genie's own chat surface — exposing it as an MCP server avoids rebuilding the genie's logic a second time for that surface. The cost you accept in return: Assign Task to Genie is synchronous, so this pattern inherits its timeout risk, and you're now responsible for describing the genie's capabilities explicitly to a client that has zero visibility into how it works internally.
When to Use It
- A custom UI or external LLM client needs to converse with a genie's capabilities directly, rather than through the genie's native chat surface.
- You want to expose a genie's skills to other agents or copilots as governed, described tools.
When NOT to Use It
- The calling context is headless or high-throughput and latency-sensitive — genie execution time can cause timeouts in the MCP client if not tuned.
- The MCP client can't be given explicit enough tool descriptions — without them, the client won't know what the genie can do.
How It Works in Workato
- Create a tool that calls the genie via Assign Task to Genie — all its usual limitations apply here too.
- Expose that API as an MCP server.
- Apply Workato identity-based authentication using the same user group that has access to the underlying genie.
Source: MCP Cookbook V1.0, pp. 22–23
