Conversational Business Process Assistants: Design and Deployment Guide
A conversational business process assistant guides employees through structured multi-step processes using natural language — replacing forms and system navigation with conversation.
AI Solutions Conversational AI
What Is a Conversational Business Process Assistant?
A conversational business process assistant is an AI agent that replaces structured forms and multi-step workflows with guided natural language interaction. Instead of requiring an employee to navigate three different systems to submit an IT request, the assistant asks clarifying questions, gathers the necessary inputs, and submits the request on the employee's behalf.
This class is defined by two things: structured process (there is a defined workflow underneath the conversation) and guided interaction (the agent leads the user through the process, it does not conduct an open-ended conversation).
How It Differs from a Generic Chatbot
A generic chatbot answers questions from a knowledge base. A conversational business process assistant takes action in enterprise systems. The distinction matters for design: a chatbot can be built on a knowledge base alone; a business process assistant requires Skills — governed, auditable actions — behind every step.
The other difference is guidance. A generic chatbot follows the user's lead. A business process assistant follows a process: it asks specific questions in a defined order, validates inputs, handles exceptions, and knows when to escalate to a human.
Powering the Conversational Layer
Workato's Agent Studio powers conversational business process assistants with two core components:
  • Skills — governed recipe-backed actions that the agent can take at each step of the process
  • Knowledge Bases — the process documentation and policy information the agent uses to answer clarifying questions accurately
The 4-level prompt design framework (Genie job description, Skill prompt, Field hints, App Events) controls how the agent behaves at each interaction point.
Common Enterprise Use Cases
  • IT help desk — the agent triages requests, gathers information, and routes to the right queue or resolves automatically
  • HR onboarding — the agent guides new employees through benefits enrollment, equipment requests, and access provisioning
  • Procurement requests — the agent collects purchase request details, validates against policy, and routes for approval
  • Travel and expense — the agent processes expense submissions with policy validation and manager approval routing
Handoff to Humans
Every conversational business process assistant needs a defined handoff pattern: when does the agent escalate to a human? Design the escalation criteria before building the agent. Common triggers: request value above threshold, exception to policy, user explicitly requests human, agent confidence below threshold.
Put these cookbook patterns to work
Get started
